Hi Folks...
When power is applied, should the LED light-up?????
SHould the LED blink once a connection is established to the Razor head?????
Regards
V16 Power
Re: V16 Power
Yes it should start a flash once per second.
In case it is connected via RS232 port number 2 to a A14 or A16 intercom (audio and control digital link) and all is well it will give a double flash once per second. If there is a problem on that link (unreliable connection) it will flash rapidly.
Re: V16 Power
OK thank you.
I'm using a DB25 to do my wiring connection and somehow the Pin 23(gnd) on board was faulty,
the foil on the PCB board was cut/scratched so no ground. I have used Pin 22 which is interconnected.
What a relief as I thought I had scrapped the V16 somehow.
![Very Happy :D](./images/smilies/icon_e_biggrin.gif)
