V16 adjustment
mikeh
V16 adjustment
Post by mikeh »
Hi all,
I've recently replaced my V10 with a new V16. I've spent some time adjusting settings and now have it working quite nicely, although the microphone setting I have arrived at seems a bit extreme. Can anyone comment please?
The radio is in my Murphy Rebel cabin homebuilt, which is a bit noisy in the cockpit. I have Bose A20 headsets with the standard mic muffs.
It is set with VOX at 3, mic at -10.5, and squelch is -99. The mic setting was chosen after comparing intercom and radio transmission volumes as Rainier suggests, but seems a long way from mid range?
Otherwise I'm pleased with it.
Any comments will be appreciated.
Re: V16 adjustment
I have given the V16 a really wide range of adjustment to suit all possible environments and headsets etc.
In other words - there is no "midpoint". If you are happy with a particular setting that suits your aircraft - stick with it.
mikeh
Re: V16 adjustment
Post by mikeh »
Thanks Rainier,
I was hoping you might say something like that! I'm certainly happy with it, it's one of the nicest radios I've used.
