Just to follow up further on my GPS issue.
Firstly, I believe my MGL Voyager EFIS's being ten years old are still worthy of being fixed if you can do so or find someone who can do this for you. My EFIS's have 1000 hours of flight time and I would say another 600 hours being powered up whilst on the ground. So you have to expect with the hostile environment of an airplane with the engine vibration this will take its toll over time.
This post is for general background knowledge,
please make sure you have the electronic knowledge and skills if you do something like this or find someone who does. Yep, if you let that magic smoke out, it's near impossible to put it back without lots of money, its much easier that you don't let it out.
So I opened up and removed the GPS /USB Board from the EFIS, in my situation I had the USB power upgrade done so I had some de-soldering to do, before I could get the board out. I had a good look and then a good clean and good look again at the board's components etc.
- Voyager GPS USB Board.jpg (55.29 KiB) Viewed 36715 times
After having a good look around with a Electronics mag scope, I found what could be causing the "GSP not Available" and "GPS Available" problem. As you will see in the pic, there is a very small crack that does go around the SMA antenna pin and there is a crack on one of the support/ground pins as well. So I re-soldered all the SMA pins to the PCB board.
- GPS SMA Antenna Pin Crack.jpg (98.68 KiB) Viewed 36715 times
As I reinstalled the EFIS and instrument panel, I added some copper foil for a ground plane on the inside top of the instrument panel under where my GPS antennas sit on top, the foil is not currently earthed. This seems to work as I have never had any GSP signals before with the plane in the hanger. But now I can get a GPS fix.
Have I fixed the GPS issue of losing the satellites and getting the "GSP not Available" and "GPS Available " warnings? Well, after an hour of 3 short flights, I am yet to hear bitching Betty or see the GPS lose its fix, so a few more hours could tell the story.
Disclosure The copper foil is self-adhesive and I feel it would do the job for my trials, but this copper sheet adhesive could easily fail with the sun heating up the dash and having a copper sheet falling into the back of your electrics and switches could be an easy way to have a major disaster. I am planning to fiberglass this copper sheet into place after a short time with proof of concept.
