I have grafted on the wires of the supplied OAT sensor to the relevant wires of the iBox PWR connector. As I understand it, OAT green goes to iBox black on pin 4 and OAT red goes to iBox green (TMP) on pin 9. I have used solder sleeves, which are new to me
But how to test my work? Should there be connectivity across these pins? Do I need to apply voltage and measure resistance? Perhaps I should leave well enough alone until the iEFIS system is powered up and just see if it works, but it would be more difficult to fix at that stage.
I notice that there are two other cores in the OAT sensor cable, yellow and black, which are just snipped off.
OAT wiring - testing?
Loman
Arklow, Ireland
Vans RV9 Tailwheel Tip-up. Slow, (very slow) build
O-320, Full MGL system
Airframe complete, currently installing FWF and electrical systems
Arklow, Ireland
Re: OAT wiring - testing?
The temp sensor in the OAT probe is technically a "chip" so it won't be as easy as just using a DMM to check. Rainier might be able to chime in, but as long as the connections are secure and don't move - or otherwise the solder in the sleeve has properly flowed, then you should be perfectly okay.Loman wrote: Tue Apr 06, 2021 5:12 pm I have grafted on the wires of the supplied OAT sensor to the relevant wires of the iBox PWR connector. As I understand it, OAT green goes to iBox black on pin 4 and OAT red goes to iBox green (TMP) on pin 9. I have used solder sleeves, which are new to me
We use the popular LM335 sensors.
We supply them with a small current and they "drop" a voltage which is dependent on temperature. It is easy to test them as follows:
Voltage drop is linear and proportional to temperature in degrees Kelvin with every degree equal to 0.01V.
0 degrees C is 273 degrees Kelvin = 2.73V (32 degrees F)
30 degrees C is 303 degrees Kelvin = 3.03V (86 degrees F)
The iBOX simply measures the voltage with respect to ground at the RDAC.
OAT connecting
I am trying to figure out how to connect my OAT probe to my Vega EMS-1. I can't find any reference to doing this in the manual.
I guess it needs to be connected to one of the analog inputs? That would be the Orange, Green, Gray, or Red/White striped wires?
The other wire would be connected to ground, I'm guessing? Does it need to be connected directly to the engine, or can it be connected to a ground bus?
The probe has one black and one red wire. Does it matter which one is connected to the EMS-1?
Dan Knezacek
Dan Knezacek
Black to ground, red to input, pullup resisdtor ON, set sensor as LM335 type.
Sometimes Green is ground too.sparxfly wrote: Sun May 08, 2022 8:11 pm Black to ground, red to input, pullup resisdtor ON, set sensor as LM335 type.
So the pullup resistor goes from the input to 5v, or 12v?
Is the resistor directional? There were 3 or 4 resistors that came in the package, are they all the same?
Dan
Dan
