EMS-2 with Rdac XF and also Xtreme
markkkk42
Post by markkkk42 »
I have a Extreme and a RDAC XF and I also have a EMS-2. I have setup the Extreme with the RDAC and all the sensors work fine but slaving the EMS-2 on the CAN bus not all the parMTERS ARE CORRECT ON THE EMS. THE OIL TEMP AND OIL PRESSURE HAVE WRONG VALUES LIKE THEY ARE NOT CONNECTED. ON THE CAN BUS I WOULD HAVE THOUGHT ALL THE PARAMETERS WOULD BE DISPLAYED ON THE EMS. oops sorry about the caps.......All the paramters on the EMS are referenced to the RDAC on the setup. EGT and CHT work all ok
Any ideas. I am pretty sure I have everything setup correctly
Franz
Re: EMS-2 with Rdac XF and also Xtreme
Post by Franz »
Select RDAC for the Data field under the analog setup menus.
markkkk42
Post by markkkk42 »
Hi Franz
I have done that on every parameter on the EMS-2 that has the RDAC selectable and also selected number 1 on all of them.
Also my Gen2 Xtreme does not display the 6 paraamters in the top right of the display as shown in the Gen 2 manual. I have the latest 2.08 firmware. I did a post about it as well
