DC Current sensor calibration
daylef
Post by daylef »
Hi. I've had a DC magnetic sensor hooked up to an RDAC for some time and have never been able to get it calibrated. It will only show negative current (or positive current when reversed) and a shunt connected in the same line shows completely different results when displayed on a multimeter. Attempts to calibrate it using the method in the manual have never worked in giving a linear result. The nearest magnetic source is about 100mm away in case that is an issue. So my question is, is there some other means to show current on the XTreme EMS such as a shunt?
Dayle...
mikeh
Re: DC Current sensor calibration
Post by mikeh »
Hi Dale,
I had a similar experience with mine and eventually put it in the bin. I just use my volt reading, which is a pretty good indicator.
We do have a closed loop current measurement device now which is compatible. This is not sensitive to tray magnetic fields and does not have to be calibrated (other than the "zero" point).
Rainier
