A16 V16 via RS232 on port 2
How does one adjust the sidetone when using the digital link between A16 and V16s. Thanks.
Re: A16 V16 via RS232 on port 2
I am not near the aircraft until this coming weekend, when I set mine up I didn't have to touch the sidetone so can't answer it off the top of my head.
I'll see what happens when I alter the intercom level on the v16, which is how you would normally alter sidetone.
There is no sidetone level adjustment as such - it's really part of your A16 volume adjustment.
Once you use the digital link - the intercom and the radio really form one unit now and all the individual settings you had before fall away.
