TP3 installation
doug.ritter@att.net
TP3 installation
Post by doug.ritter@att.net »
TP3 Newly installed and everything seems to be working except the screen flashes ?
Re: TP3 installation
Can you be more specific ?
You don't just have an alarm active ? Check your settings for that...
doug.ritter@att.net
oil pressure and oil temp flashes but channel 3 voltage doesn't. I'm not using the alarms but I'll double check.
