Feature Request: Add to VSI, "Needle is small triangle"
As it says in the title, I'd like to make an analog VSI needle on a transparent background to crawl around the outside face of my analog altimeter, and the thing that's stymie'ing me is that I can't change the needle from the stock one. It would work perfectly if I could use the "Needle is small triangle" checkbox that exists for some other instruments.
