FF4 - filter
Valsoar
FF4 - filter
Post by Valsoar »
can someone please explain the filter parameter when setting up fuel levels?
Re: FF4 - filter
It determines how fast the level indication reacts to changes in fuel level sender output - in effect you use this to eliminate the effects of fuel sloshing around in your tank. It's variable so you can tweak the behavior to your liking.
