MGL Avionics Users,
I am Adam from Michigan Avionics, the new exclusive USA Sales and Support for MGL Avionics. As many of you are likely aware, MGL Avionics USA had maintained a vast knowledge-base with tons of topics covering most of the MGL Avionics line-up. Since the transition in the US, many have noted that the knowledge-base has gone offline.
Michigan Avionics has taken over all data from the knowledge-base and has placed it on our support system, available at support.michiganavionics.com.
We are also adding new items to the knowledge-base all the time, and are happy to accept suggestions from MGL users on information that would be useful to add.
Thanks!
Adam
MGL Avionics Knowledgebase
Re: MGL Avionics Knowledgebase
Hi Adam,
some possibilities i know of:
-Wrong setting of sensor gain (pulses per gallon)
-in case of engine installation with reflow line no return flow sensor (eg Rotax 914 has about 27gal/h fuel flow forward here)
-sensor broken
-bad sensor
but for sure no issue to buying a plane![Wink ;-)](./images/smilies/icon_e_wink.gif)
best regards,
Steffen
-sensor broken
-bad sensor
best regards,
Steffen
Steffen,
I think your reply ended up in an incorrect location...
Adam
Adam
