V 16 green flashing led
TrikeStefan
Post by TrikeStefan »
hello. i have a v16 transmitter with the razor display and everything works very well. but what does it mean when the green led flashes ? i could not find anything in the manual about this. greetings stefan
Re: V 16 green flashing led
It means the V16 is happy. We use flashing LEDs on most of our products, sometimes with variable flashing sequences to signal specific states. In case of the V16 it just does a regular flash. It is switched on and off by the processor as part of its normal program execution. So if it flashes it means the processor is running its code.
