FuelP issue on Gen 1 Xtreme EFIS
Posted: Thu Oct 01, 2020 6:32 pm
Equipment: Gen 1 Xtreme EFIS (with 1.36 Firmware)/RDAC XF MAP (Communicating with Airtalk)/UMA N1E100G(M)
All inputs to Xtreme (EGT,CHT,Fuel Flow, OilP, OilT, RPM) work fine except FuelP with UMA N1E100G(M).
With PU resistor for FuelP "on" ADC Menu value for FuelP displays "0". PU resistors "on" for Aux1 and/or Aux2 inputs show ADC Menu positive values.
With UMA N1E100G(M) signal plugged into RDAC Aux1 or Aux2 (PU resistor "off"), ADC Menu Aux1 and Aux2 voltages vary with fuel pressure.
With UMA N1E100G(M) signal plugged into RDAC FuelP (PU resistor "off"), FuelP display stays 0 for any fuel pressure & ADC Menu shows 0 voltage.
Gen 1 Xtreme EFIS with Airtalk interface seems to have a placeholder screen for FuelP, but does not "look" for the FuelP input to the RDAC XF MAP.
Solution?
Solution?
