Terrain file from elevation data
plippo
Post by plippo »
Living in Finland means that we're outside the 60N - 60S area of USGS shuttle elevation data area, so I'm trying to compile a high resolution terrain elevation data from other local sources. However I haven't found a method to do that in MapMaker or other tools. Is there a tool to do that?
plippo
Re: Terrain file from elevation data
Post by plippo »
And I just saw the other post which explains that MX1 does not have any terrain features. That means that the terrain generation is no longer relevant to me...
I'm leaving the post here in case it helps someone else.
