MGL_Central on command line?
plippo
Post by plippo »
I'm trying to automate the airspace conversion from ARINC424 (OpenFlightMaps) to EFIS MX1 and while the conversion worked ok (after I changed the LF to CR/LF in the file), I can't find command line parameters from the documentation. I tried the usual --help, -h, /? /help, but those just open a window complaining that the data format is invalid.
Any ideas?
