Stratomaster Velociy and Vega
rotorgoat
Post by rotorgoat »
I currently have the 3 1/8" Velocity installed in my panel with Oil Press & Temp, EGT and CHT, RPM and Voltage inputs. Can I switch to the Vega and connect the existing sensors to it?
Re: Stratomaster Velociy and Vega
Yes but you likely want the Blaze which is the same physical size. Vega is the 2.25" range.
