Trying to set-up using version 1.1.2.2 and it's not seeing the RDAC and my version1.1.1.0 does????
Any hint???
Regards
Design/simulator 1.1.2.2
Re: Design/simulator 1.1.2.2
Are you getting no response from the sliders; or do you see "X"s over the gauges?
Sorry if I am stating the obvious, but have you clicked the RDAC ON/OFF button at the upper Left?
Thank You Bill for stating the obvious, I had miss the obvious or more that
I was not looking in the right place....
Bill.
If you don't mind and maybe missing the obvious, On the simulator my speed indicates 251 which stop me
to have access to certain option.
Can you give me a hint on where I can set it to zero????
Regards
Regards
251 is the Max possible airspeed.
This tells me that the "Dynamic Pressure" Slider (the middle one) on the "Pressure Sensor Simulation" Window is Maxed out.
Set it to the Bottom for Zero.
Set it to about 10% for typical GA Airspeeds.
Yep that was it... Thx
