iEFIS G3 Firmware update 1.1.2.2
Added support for Microkit Wifi interface to HS RS232 port 1 on iBOX based iEFIS systems (RS232 port on rear of panel).
Added selectable fuel level alarms (similar in function to engine related alarms). Applies for all tanks. Note: Use with care and should only be enabled if fuel level readings are reliable and repeatable.
Added support for new iBOX V2
Increased Watchdog timeout interval to prevent system restart if card storage operations take longer than usual.
