MAP on the RDAC XG possible?
TimMc
Post by TimMc »
Hi
I have purchased an aircraft with Xtreme ems and RDAC XG. I would like to add MAP
Can i use an external MAP sensor, and feed that that into AUX1? And then if so, Can that then easily be displayed on the EMS.
Tim
Re: MAP on the RDAC XG possible?
You could miss-use the oil pressure functionality for this with a suitable sender but there is nothing you can do on the AUX inputs.
Sorry - the XG was never meant to support manifold pressure.
