MGL Central
VH Bill
MGL Central
Post by VH Bill »
The following message was displayed when I selected the Google Maps option:
You are using a browser that is not supported by the Google Maps JavaScript API.
Is the current version of MGL Central compatible with Google Maps?
Thanks for your help
Bill
Re: MGL Central
Google maps are no longer available for free on PC platforms and the way the map data was retrieved has been blocked.
VH Bill
Re: MGL Central
Post by VH Bill »
OK, thanks for the reply.
Where can I get MGL Maps for MGL Central and does that map data cover Australia?
Bill
Re: MGL Central
You can use vector maps (download from our website), then download the matching terrain data for your area. If you have a navidata file you can use that for the navigational items (airspaces, airports etc).
MGL Central has not been updated to Mapmaker2 map format so if you want to use raster maps you need to convert your raster maps using the MapMaker (not MapMaker 2) for use with MGL Central.
VH Bill
Re: MGL Central
Post by VH Bill »
Thanks for your reply.
Bill
Re: MGL Central
Seems Google has switched off the java API support in August completely. The error that pops up leads you to a link suggesting possible fixes - I tried them all, nothing does anything.
Might have to change things to Bing...
