MX1: W&B (solved)
MX1: W&B (solved)
Rainier,
Ever since I installed the MX1 I've had trouble getting the W&B to calculate zero fuel w&b. Turns out I didn't understand that the W&B feature can use actual data or entered data. I was using "fuel entry" and not "fuel 1(1)".
So I've discovered (at least on the simulator) that W&B will not calculate zero fuel when using "fuel entry" but does when using "fuel 1(1)" (tank1 RDAC1). Can you make manually entered fuel also calculate the zero fuel cg or does this need to be disabled?
