V10 placement
drmud90
V10 placement
Post by drmud90 »
I am creating my instrument panel with an Odyssey EFIS on the left and a Garman GTX 327 transponder in the center with a V10 above the GTX327. How much separation should I have between these devices to avoid interference?
Re: V10 placement
No interference should be expected. Ensure good wiring practices related to audio wiring and in particular ensure your antenna is correctly fitted and tuned - interference usually enters antenna (to close to interfering source(s)) or couples straight onto your antenna cable as a result of a mismatched antenna.
