ECB D9
Loman
ECB D9
Post by Loman »
I am installing a string of 3 ECBs. I believe I am clear on most things except the wiring of the PWR+ pins on the D9 connectors
The manual says "Note: Supply current for ECB will be taken either from the breaker input terminal or the supply pin 4 on the D9 connector depending on which voltage is the higher."
I find this confusing because I assume these pins would be connected directly from the Master Bus, just like the main input terminal posts. So they should be electrically identical and I can't see how one would have a higher voltage.
What am I missing here? If not the Master Bus, where should D9 pin 4 be wired from and what fuse should protect it?
Loman
Arklow, Ireland
Vans RV9 Tailwheel Tip-up. Slow, (very slow) build
O-320, Full MGL system
Airframe complete, currently installing FWF and electrical systems
