MX1 firmware version 9 available
From our firmware update page at:
www.mglavionics.co.za/mx1ups.html
This fixes an issue discovered related to tilt compensation of a connected SP-6 compass. The problem caused unstable headings or skipping of several degrees while turning. This was caused by slight differences between the processors instruction set behavior when compared to that of a regular G3 iEFIS.
