Blaze EMS - RDAC water temp Rotax 582
Posted: Wed Jun 18, 2025 2:41 pm
Hello knowledgeable people
Some help and direction needed as ive exhausted mine. Got Blaze EMS talking to RDAC ok green flashing light, EGT & EGTs screen ok. Problem hooking up the VDO water temp sender. I just get a -45deg reading in red background. Nothing I have done has made any change whatsoever, pull up on, shorting lead directly to ground. The reading does not change, its as if the RDAC is just not seeing the sender. Ive programed it correctly VDO, 120.
RDAC Earth wired as per manual, ie engine block, then via batt -ve
Any pointers gratefully accepted
thanks in advance Dave
Forgot to add this is a new installation
