I'm using a EMS-1 with an RDAC XG and I want to use one of the analogue inputs with a 0.5-4.5v 1 bar absolute transducer. I'd like to display it in "hg but the menu only gives me psi/bar.
Is it possible to display in "hg ?
I've upgraded to the latest firmware.
Paul
EMS-1 Analogue Input Pressure units
Re: EMS-1 Analogue Input Pressure units
Hi Paul,
You can do it, but you will have to change the dipswitch inside the EMS-2 to turn the internal pull up off. Select "Generic input", Select calibrate sender and set your points to 2. Enter 1st point display: 0 , adc 1 408, 2nd display in max "hg, adc 2 point 3705. Change the label, unit and decimal point.
Regards,
Franz
Regards,
Franz
