A14 specs/manual
bruceh
A14 specs/manual
Post by bruceh »
Hi.
I can't find any information on the differences between the A14 and the A16 (apart from a comment that the A14 has two less mono inputs). The only manual I could find refers explicitly to the A16 with no reference to the 14. Is there any documentation anywhere? I'd like to buy an A14 (it's cheaper, i believe, and I don't need a 6 seater system), but I'd really like to understand any and every difference between them.
Re: A14 specs/manual
The A14 uses the same firmware as the A16 so basically behaves the same.
Differences are:
4 instead of 6 microphone inputs.
Single stereo output (as opposed to the dual circuit pax/pilot of the A16).
The two NAV audio signal inputs are missing.
bruceh wrote: Wed May 28, 2025 9:13 am Hi.
