We are developing a new-entry utility gyroplane, currently undertaking the required test-flight program.
We use the Xtreme EMS to display engine parameters/performance:
The gyroplane is propelled by the EJ25 Subaru engine - 2 500 cc, 4 cyl, normally aspirated.
We do not make use of any in-line fuel flow meter, but would like to make use of the fuel-injector flow-rate as a means to display a useful fuel flow on the instrument.
The injectors used are of the standard (251 variant engine) flowrate of 550cc/min - these are high-impedance (8 to 16 ohm) injectors and there are 4 pulses per engine cycle.
If anyone has a similar set-up, providing accurate fuel-flow, please share the K-factor (and any other pertinent settings, aside from the injector impedance (high) values which should be entered) which must be entered into the EMS fuel-flow set-up menu?.
Thank-you.
Rivaero
