Hello
I am thinking about replacing my VDO Tacho/Hobbs in my Bantam with a Blaze MAP-4. I have already installed a Blaze ASV-2 so I have a spare hole.
I have a few questions..
Will I be able to use the existing RPM pickup on the Jabiru 3300 engine? If not, what is commonly used as a replacement?
Is the unit supplied with a temperature sensor? If not, what is commonly used?
I would like to measure fuel pressure instead of manifold pressure. Is this possible and if so what pressure transducer to use?
That's it for now.
MMW
MAP-4 in a Bantam
