Iefis rpm not operational
Mikemail356
Post by Mikemail356 »
I have an Stratocaster iefis explorer lite paired to a rdac XF. Everything is operational except the rpm. When booting up a red X is displayed over the rpm area and no rpm is shown. I have moved the rpm lead to the old EIS display and rpm is shown accurately indicating an acceptable pulse. Does anyone have an idea as to a solution?
Thank you
Re: Iefis rpm not operational
On the RPM1 input?
Ballast OFF?
Adjust the sensitivity screw until you get a stable reading.
Olivier
Post by Olivier »
Red cross on RPM display area indicates that RDAC data is not received. Check RDAC CAN connection, and check that RPM display field is assigned to correct RDAC number
