Reading IEFISBB.DAT File
Still_Learning
Post by Still_Learning »
Hi
I copied the internal flight data to an SD card - assume this is the IEFISBB.DAT file. When I use the "import" function in BlackBox viewer, it tells me 7 flights imported, but I then can't seem to select a flight or show any parameters. Is BB View just designed to handle REC files?
Andrew
