EFIS Audio On/Off function
johan
Post by johan »
I am installing my MGL (ibox + iEFIS challenger) system and trying to test as much as possible in the simulator.
It seems there is a function for the digital inputs that is labeled "EFIS Audio On/Off".
I am wondering if this is a "toggle" function or whether high means "audio-on" and low means "audio-off".
Also I would like to add an indicator to my screen with the EFIS audio state (on/off), but I can't find any existing item for this.
If it's not a toggle function, but high represent audio on and low represents audio off, I could use a digital input state in the designer. Otherwise I don''t know if it's possible to output the audio state on the screen.
The problem is that I can't test this in the simulator and I am not able to test this in the simulator as the audio output doesn't seem to work in the simulator. I can't test it in my airplane either because I am still in the process of installing all the MGL components.
I hope someone can help me with this,
Thank you in advance,
Regards,
Johan.
Tasmag
Re: EFIS Audio On/Off function
Post by Tasmag »
I have never been able to get it to work, every time i enable it in the settings i lose all audio, no matter what switching i use.
I have the A16 now so don't have the need for it anymore.
