Would anyone happen to know how accurate RDACs are when using the VDO NTC thermistor type temperature senders that are usually found on Rotax engines for oil/coolant T? (50-150°C 323-19 Ohm)
They are not linear in their Temp/Resistance curve and I'm wondering if compensation is done by RDAC or EFIS.
RDAC Oil/coolant temperature inputs using VDO senders
