Fuel Flow Sender Jet size for Rotax 914
johan
Post by johan »
I am installing the MGL fuel flow sender but don't know which Jet size to choose for my engine.
My engine is a Rotax 914, burning aprox 20l in cruise.
I am a bit confused by the Jet sizes and the flow ranges.
Is there anybody who can give any advice on the correct jet size for a rotax 914?
Thank you in advance,
Johan.
Re: Fuel Flow Sender Jet size for Rotax 914
On a 914 we install one sender into one of the carb feeds using the 2mm jet (second smallest in the packet). We then "lie" about the k-factor - it should be 7000 normally - we tell it 3500. Half. This way the readout doubles. While this only really shows the flow on one of the carbs it works well.
johan
Post by johan »
Thank you for the answer. I assume this is done because if the fuel flow sender was installed before the fuel regulator the reading would be less acurate/useless since it would include the flow from the fuel return line ? I think it makes sense to install it into the carb feed, however the fuel lines from the regulator are hard (metal) fuel lines on a 914, not sure what the best way is to install the fuel flow sender.
Also, is it safe to install the fuel flow sender on the hot-side of the firewall? Not sure if an alternative solution might be to add a 2nd fuel flow sender in the return line and do some calculation to get the correct fuel flow readout.
johan wrote: Mon Nov 27, 2023 8:57 pm Thank you for the answer. I assume this is done because if the fuel flow sender was installed before the fuel regulator the reading would be less acurate/useless since it would include the flow from the fuel return line ? I think it makes sense to install it into the carb feed, however the fuel lines from the regulator are hard (metal) fuel lines on a 914, not sure what the best way is to install the fuel flow sender.
Usually the return flow on 914 installations is quite high so you would need a differential flow system with two senders. While this works it is expensive and can be fiddly to set up - it's easier to do if you have an engine that consumes much more fuel than the 914.
The flow sender is normally installed on the hot side of the firewall - on my own aircraft (fitted with 912ULS) it was fitted above the engine just before the return splitter - on these engines the return flow is very small and can be ignored. It's just to prevent vapor locks.
