earthX warning input
N43YX
Post by N43YX »
I apologize if this has been asked and answered. I used the search function and could not find anything. Is there any way to utilize an unused input on an RDAC/Xtreme combination for the battery monitoring function for EarthX batteries?
adamoconnor
Re: earthX warning input
Post by adamoconnor »
This is not directly supported on the XTremes. You could actually do it rather easily by using an AUX input with the PU switch turned on for that input, then set it up as a user-defined calibration. It would show up as a "gauge" but you could still set up the alert to know if there's an issue.
Adam
