The message “supply on backup” shows up when I turn on the back up battery switch. After I acknowledge the message it goes out. New battery and have checked wiring against the iefis diagram.
Would like to know why this message comes up.
Error message
Re: Error message
That message appears when the power supply has changed to backup supply - this in turn happens if the backup voltage is larger than your main voltage.
