Xtreme EFIS and autopilot
Timppa
Post by Timppa »
Hi!
Does anyone have any tips on why the Xtreme EFIS doesn't recognize the autopilot servos? Power is coming, meaning the LEDs on the servos are on. I've checked the connections twice. I'm an electronics installer. Where can I find the autopilot programming instructions for the Xtreme EFIS? It's not in the Xtreme manual.
Re: Xtreme EFIS and autopilot
Use either the autopilot manual or iEFIS autopilot manual - it's the same basically. XTreme does not do yaw servo and does not do approaches so vertical control is simpler but has the same settings otherwise.
You need to get the LEDs to flash. Steady light means you have not yet identified the servos (they don't know what they are supposed to be).
Connect one servo at a time and tell it to be a bank or pitch servo. Once identified the LED will flash.
