Pin 6 on the Appareo labeled: "RS232-TX GPS 1PPS"
Could this work for a GPS signal for the iBox into port 6? I'm assuming 1PPS is one pulse per second which is the limit of the port.
Also, can the serial output of the Appareo (it's a pass through from the encoder) be used into the ibox for altitude?
TIA!
TSO Appareo ESG as a GPS source for iEfis?
