MGL fuel tank sensor
mleimetter
Post by mleimetter »
I am using the MGL 12” fuel tank sensor with my Xtreme EMS. It worked fine when first installed but after running the engine for a bit I started getting very erratic readings from 0 to full. Any help would be appreciated.
mleimetter
Re: MGL fuel tank sensor
Well I took everything apart and started over. Finally was able to get it programmed and appears to be working correctly.
