LM335 for OAT
Heinz
LM335 for OAT
Post by Heinz »
Hello,
I am using an EMS-2 and RDAC-XF connected via CAN. Delivered with the EMS-2 was a sensor, I guess it is a LM335 temperature sensor (has two wires red and green). I think it is a good idea to use it as OAT sensor. So I connect it to RDAC-XF AUX1 and ground as shown in manual for RDAC-XF see pic1. At the EMS-2 I try to configure the Analog channel 1 as shown in pic2. But it doesn't work.
For my understanding, normally I need to connect the LM335 via 3 wires shown in pic3.
What is my mistake?
Thanks for support,
Heinz
Image Image Image
adamoconnor
Re: LM335 for OAT
Post by adamoconnor »
Your images did not come in.
The LM335 can connect to the RDAC - Green for ground and red for signal. Connect it to AUX1 if you want to use analog channel 3 or AUX2 for analog channel 4. Turn on the AUX 1 or AUX 2 PU switch on the RDAC.
Heinz
Re: LM335 for OAT
Post by Heinz »
It works! It seems for OAT Analog channel 4 is preferred. Also I changed to AUX2 and activates it. That's it.
Thanks for all,
Heinz
bissetn
Re: LM335 for OAT
Post by bissetn »
Normally the OAT sensor is connected to the OAT sensor input on the rear of EFIS not to the RDAC
manolo.lezl
Re: LM335 for OAT
Post by manolo.lezl »
Hello.
Will Dynon OAT probe 100433-000 work with my iEFIS?
I don't know if it's based on LM335...
Thank you.
