iEFIS G3 1.1.0.5 update released
Improved video timing for VGA output (for standard timing selection in Operations setup menu).
Added: A collection of new touch fields for Screen designer: Reset G-Force min/max, Direct page number selections, also next and previous page - similar to page selection via Rotary control but you can now do as touch field. Also added touch fields for direct autopilot engage similar to what you can do via remote buttons.
Added a new Oil/Fuel pressure sender type: UMA 0.2 to 4.7V range.
You can now add a N16 navigation receiver or a combination V16/N16 as NAVCOM as COM2 - you still only have one navigation radio in this case but the N16 connected to COM2 will work as iEFIS navigation radio. This case allows you to use another radio as COM1 (Note: Only one navigation radio per system - you cannot have one connected as COM1 and COM2.
