V6 Remote Flip-Flop
Posted: Thu Dec 24, 2020 5:07 pm
by andoman
Is there a way to wire a simple external momentary push-button switch to activate the flip-flop function of my V6?
I have no EFIS so no RS-232 data in.
The goal is to activate the flip-flop function remotely from my fancy stick grip.
Thanks so much, and Merry Christmas!
Enjoy the holidays!
Re: V6 Remote Flip-Flop
Posted: Sun Dec 27, 2020 8:35 pm
by andoman
Enjoy the holidays!
Posted: Thu Jan 07, 2021 1:21 pm
No there is no such function on the V6. Sorry.
Posted: Tue Feb 02, 2021 9:10 pm
by S18Pilot
Trying to flip active and standby frequencies in the V16. I send byte sequence
0x02,0x05,0x12,0x00,0x12^0x55
which appears to be correct from the V16 ICD. But the frequencies do not flip. What am I doing wrong?
Thanks.
Posted: Wed Feb 03, 2021 9:48 am
S18Pilot wrote: Tue Feb 02, 2021 9:10 pm Trying to flip active and standby frequencies in the V16. I send byte sequence
Thanks.
That's correct. Make sure all other com parameters are good (One stop bit, no parity). And of course that that data actually gets to the RX pin...
Posted: Wed Feb 03, 2021 2:39 pm
by S18Pilot
No joy. I can write the active and standby frequencies individually, with commands 00 and 01, so I know the serial port link is working. I've verified the byte sequence and that the sequence is being written for the command to flip frequencies. Not sure what else to try.
Posted: Wed Feb 03, 2021 7:35 pm
by S18Pilot
Same problem with commands 02 and 03 to change RX/IC volume, and commands 05 and 06 to change squelch. Values are not changing. Byte sequence for command 02, for example, is
0x02 0x05 0x02 0x00 0x57
0x57 is = 0x02^0x55
Any suggestions would be greatly appreciated. Thanks.
Posted: Wed Feb 03, 2021 10:15 pm
by S18Pilot
Got the commands working. Deleted the "00 Don't care value" shown in the ICD.
