A16 Protocol Questions
Posted: Sun Sep 05, 2021 5:20 pm
I'm working on the XFS driver for the A16 audio panel and just want to confirm a few things:
1) With the CVR function, it does not appear to be the case that you can repeat the last received transmission (e.g. from COM1 or COM2). Is that the correct understanding? If not, can you direct me to a way to do so?
2) The setup protocol does not appear to provide a way to set the volume, gains or vox to a specific number but rather require incrementing or decrementing the current value. Is that correct? If not, can you point me to how to set those values and if my understanding is correct, I'd like to request a way to set these values to specific numbers. The increment/decrement approach is not conducive to the type of highly redundant driver model we use within XFS.
Thank you!
Mark
Thank you!
Mark
