Two transceivers, one antenna
Posted: Wed Dec 09, 2020 11:47 am
A bit of advice required for something I have never done before.
Currently, I have a Funke ATR833 in my aircraft. But I also own a MGL V16 which I have never installed. I am using a N16 with a Blaze control head. Because everything is in place, it would be easy for me to install the V16 box and have a 2nd radio. I would just hookup the PTT to a selector switch so it would only send the PTT press to a single radio.
My problem comes with the antenna. It would be a lot of work to install a 2nd antenna so ideally I would want to run both radios off the same antenna. I am aware you can't just splice them both to the same antenna else the transmitting radio would just send all it's power in to the other one and possibly damage it.
I just wondered if there was an easy solution to this. I know RAMI make a device that will automatically isolate the 2nd radio when the primary transmits, but the cost of it just doesn't make that solution financially viable.
I was thinking maybe a coaxial relay but not sure which one would be suited to the task. I could even configure everything that if you power on the 2nd radio, the first one would power off as realistically, only one radio at a time needs to be powered on.
Any advice would be much appreciated. So to summarise, I need to connect 2 transceivers to the same antenna, but only 1 transceiver needs to be powered on.
