V16 isolated jacks for mic and heaadphone
Posted: Fri Mar 29, 2024 10:42 am
by manolo.lezl
Hello.
I have installed those jacks with no contact with frame as remarked on the installation manual. When I connect the DB25 conector on the V16 radio, the shield of those jacks get in contact with frame via the radio GND.
This is the way that should be, right? GND connection only via V16 body.
Thank you.
Re: V16 isolated jacks for mic and heaadphone
Posted: Fri Mar 29, 2024 1:03 pm
by andynoiseboy
Yes. The principle is that if you also ground the jack socket, say, to the airframe, you will create a ground loop which can cause many issues.
Posted: Wed Apr 03, 2024 6:43 am
by manolo.lezl
Great, thank you.
