Vega TP-3 settings
BJT
Vega TP-3 settings
Post by BJT »
Just installing a TP-3 in place of an older monochrome TP-1 so hoping someone can point me in the right direction please?
With the Display Max setting does this value apply to both the coloured bargraph AND the digital display or just the bargraph on its own? I assume the latter as the manual says:
Display Max:
Select the maximum pressure that you want the bargraph to show. This can give you increased display resolution
adamoconnor
Re: Vega TP-3 settings
Post by adamoconnor »
The value itself will display as high and as low as the sensor value allows.
BJT
Post by BJT »
I assumed that was the case but just wanted it confirmed before I set it all up. Thanks for your help
