Vega ASV-1 Question
Posted: Tue May 03, 2022 7:40 pm
by N91SX
If you disable the VSI in the menu will you get an airspeed ribbon in it's place?
Re: Vega ASV-1 Question
Posted: Fri May 06, 2022 9:38 am
by Franz
Hi.
The VSI bar will just disappear. A good suggestion though to replace it with the airspeed ribbon.
Franz
Posted: Mon Aug 08, 2022 6:25 am
by Franz
ASV-1 and ASV-2 firmware has been updated to accommodate this.
Franz
Posted: Fri Jan 13, 2023 9:54 pm
by mwtucker
Can you say more about the change to the firmware? I noticed in the manual that the airspeed setup section prompts for a number of V-speeds. How are these V-speeds used? Is there a color associated with the speeds (e.g. corresponding to the green arc, white arc, redline, etc.? If I understand the firmware change, if the vertical speed is disabled, a colored airspeed tape will take its place?
Posted: Thu Jan 19, 2023 11:01 am
by Franz
Yes, a colored airspeed tape can be displayed with different colors for the Vne, Vno etc.
