BLAZE EMS-2 & RDAC FL1 vs AUX2
rich
Post by rich »
I have installed the EMS-2 connected to RDAC XG and I'm wondering how to properly connect the fuel level sender.
Engine: ROTAX 912
EMS-2 Analog Channel 4: MODE: "Fuel level"
Connection of sensors:
RPM -> RPM1 @RDAC
Current sensor -> Current @RDAC
OilP (4..20mA) -> OilP @RDAC
Oil Temp -> OilT @RDAC
CoolTemp -> AUX1 @RDAC
Fuel Level -> FL1 or AUX2 ???
Re: BLAZE EMS-2 & RDAC FL1 vs AUX2
Best to use FL1- that is its intended use.
Routing, signal conditioning, tank linearisation and display are all available to you by default using that input.
rich
Post by rich »
Hi Stuart,
thank you very much for the quick reply.
I had the same thought but the manual of the EMS-2 says that the analog channel 4 is mapped to aux2 of the RDAC. So how can the mapping be changed to FL1?
Select RDAC as the source for that channel- that way it will pick up the RDAC FL input.
The bits in the manual re analog channel setups mainly relate to using the direct analog inputs on the EMS2.
