Send a GPS-NMEA 0183 via RS232
Posted: Sat Jan 14, 2023 8:25 pm
by GeorgStein
Hello,
is it possible to send a GPS-NMEA 0183 via RS232.
System:
IEFIS Lite with Extender
Thank you Georg
Re: Send a GPS-NMEA 0183 via RS232
Posted: Sun Feb 19, 2023 12:04 am
by Bill Hertzel
In theory, by using ...
Menu>System Setup>Serial Port Routing
You can define a serial port as a "GPS NEMA Port"
I have tried to use this to send location data to my ELT but have not been successful.
I would also like to know if anyone has made this work.
Posted: Mon Feb 20, 2023 3:28 pm
Make sure you select the correct baudrate to be compatible with your ELT. You do this in your GPS and NMEA setup menu. The NMEA feed contains all required messages.
Posted: Mon Feb 20, 2023 7:19 pm
by Bill Hertzel
I am pretty sure I matched the baud rates, but I'll Check it again.
Thanks.
Posted: Wed Sep 20, 2023 2:08 pm
by jeffnschofield
Did you get this working? I'm having the same problem.
