Hi Ranier,
I have the IEFIS G3 Explorer, SN200300411, the SD card reader seems to be set rather deeply in the EFIS case. I have rather short nails and sometimes have to uses a fine screwdriver blade to ensure the card has gone in far enough to seat properly, also to unseat and eject it as the edge of the SD card when inserted and in place is sometimes just out of reach of my fingernail.
What should be the position of the edge of the SD card when inserted and in place. Should it be visible and protruding slightly or should the SD card edge not be visible?
SD Card Receptacle
Re: SD Card Receptacle
Find this post, your SD module sounds like it's stuffed.
Search for this post "iEFIS dicky SD card slot" in EFIS Systems
